Still getting Detonation???
Old May 8, 2005 | 02:56 PM
Blown Interceptor's Avatar
Default Still getting Detonation???
After the new fuel pump and finally scanned my car for timing. I just tested it out w/125 shot. Detonation when I first spraying. My timing is around 27*, then is starts to drop, maybe it will go as low as 21.5-23,but all in all it stays around 24-27*.
What does everyone think? Could I be running too much timing?
**If anyone has EFIlive, I could email them the file, and get some thoughts on maybe whats going on.**
Thanks for the feedback!
Jason
Old May 9, 2005 | 02:14 AM
Formula_Power's Avatar
what octane fuel are you using...if your only using 93....i would upgrade to at least 100 and see if it gets better...if you are detonating it can only be a few things.....to much advace timing.....too low octane fuel.......and of course no fuel at all....is all your fuel pressure readings look good??.....also you maybe want to back down to a 75 shot and test it
Old May 9, 2005 | 10:11 AM
The only octane we have here in Ca is 91. If I drop down to a 75 shot...and the detonation goes away, would it be a timing issue?
Thanks,
Old May 9, 2005 | 11:20 AM
Robert56's Avatar
Try upping your fuel jet a size at a time, every combo is different. Also, engine temp plays a role, try setting fans down if you haven't allready. On wet hits you usually see a lean spike upon activation, the n2o gets to the cylinder first then the gas, does it go away right after intial hit?
Old May 9, 2005 | 06:01 PM
I have a manual fan switch, so cooling the engine is ok. It will go away right after I first start spraying, usually within a couple hundred rpm's, like 500-700.
Thanks for the imput...
Old May 10, 2005 | 12:16 AM
Green Thunder's Avatar
What plugs are you running?
Old May 10, 2005 | 09:04 AM
Autolite 103
