Need help. Harlan window switch w/ TNT F1
Old May 18, 2005 | 02:17 AM
Unstang's Avatar
Default Need help. Harlan window switch w/ TNT F1
Can someone clue me in on the install of the Harlan Window Switch with a TNT kit?
Thanks!
Old May 18, 2005 | 11:29 AM
David@TNT's Avatar
Thanks!
http://www.texasnitroustechnology.co...structions.pdf
Old May 19, 2005 | 12:34 AM
Unstang's Avatar
Thanks David!
Can someone clarify what # corresponds with each color on the relay of the TNT kit? I want to be 100% sure that I don't have something hooked up wrong before I test it out.
Old May 19, 2005 | 07:50 AM
aNuBiS's Avatar
David, do the grounds of the solenoids HAVE to be wired to the FPSS or can we ground them to the chassis. Thanks
Old May 20, 2005 | 10:54 AM
David@TNT's Avatar
No, use the fpss to break the ground on pin 85.. Grounding the sol directly to the chasis is the best way, I will correct the wirng diagram soon..
Old May 20, 2005 | 09:16 PM
02SOMWS6's Avatar
Good info guy's
Old May 21, 2005 | 10:10 AM
Unstang's Avatar
Thanks David!
FWIW, in case someone else is like me...If you pull the relay apart, the prongs are marked with the numbers, it makes wiring this kit with the TNT instructions very straight forward.
Old May 23, 2005 | 04:14 PM
bad2000ss's Avatar
We used two relays for the install. One for the window switch and one for the 2-Step. Here's a little wiring diagram. You would most likely using simple push/release button for activation rather than wiring through the transbrake.
