860 Bottle Bracket Heater SAVE NOW!!!!
Old May 18, 2005 | 10:47 AM
Nitro Dave's Nitrous Outlet's Avatar
Default 860 Bottle Bracket Heater SAVE NOW!!!!
Hey Guys 860 has made some changes on there heated bottle bracket.We are going to clearance out the old ones to make room for the new.So get in on this deal while its here.
For you guys that are not familiar with the heated bracket.
This is basically a hot plate with bottle brackets.This a very nice unit.
They normaly sell for 124.00.They are on sale for 95.00 while supplys last.
This is the heated unit not the automatic unit.
Here is a link
http://www.nitrousoutlet.com/outlet/...&section_id=61
Thanks
Dave
Old May 18, 2005 | 07:11 PM
cyipher's Avatar
what did they change on the new heaters?
Old May 18, 2005 | 07:23 PM
860 Performance's Avatar
The overall design of the new heated brackets is the same. We listened to our customer feedback, and changed some of the components. One difference is that the new fully-auto heater kits will now include an adjustable pressure switch instead of a fixed pressure switch.
Old May 23, 2005 | 04:38 PM
To the top
Old May 23, 2005 | 10:29 PM
Robert56's Avatar
These are nice brackets, makes for a very clean install. I was wondering what the wattage is new/old?
Old May 24, 2005 | 07:45 AM
Robert,
The previous version was 175W, and the new ones are 225W.
The watts can not be directly compared to standard silicone style heaters.
Here is a link that shows heat rate of a 175W bracket heater vs. a conventional 240W silicone heater.
http://www.860performance.com/860Products.htm
(check out the starting bottle temperature, and ambient temp for the test conditions)
As you can see the heated bracket starts a little slower because it needs to also heat the mass of the bracket, but then heats at a slightly faster rate, even though it uses less power. This is because heat transfer of the aluminum is faster than silicone. The mass of the bracket then is in your favor once the bottle is up to temp, because it helps keep the bottle temp more stable.
Testing is done on the 225W bracket, so expect an update to that page in the next week or so.
Vinny
