Sorry, i couldnt find anything. m6 and wetkits
Old May 18, 2005 | 08:21 PM
vince3's Avatar
Default Sorry, i couldnt find anything. m6 and wetkits
i found a good deal on a wetkit, i was thinking to use it on my 6sd car. i can only remmember the numerous backfires on my lt1 car with and nx wetkit(A4)
will this thing back fire when i shift? im not real fimila with how window switches work, i know they can cut the nitrous off at a certain rpm, but can they cut the gas off to?
should i just convert the kit to a dry kit?
will the pills be the same?
Vince
Old May 18, 2005 | 08:32 PM
calongo_SS's Avatar
yes the window switch will shut off the fuel and nitrous noids. If you didn't have one on your old set up that's probably why you had backfires.
Old May 18, 2005 | 10:25 PM
silverZ98's Avatar
i have a 2 month old msd window switch that going ot be for sell here in the next few days. with 3000, 4000 and 6000 pills for it. let me know if your intrested in it
Old May 18, 2005 | 10:53 PM
NXJeremy's Avatar
Definately get a window switch for a M6 car, and is also not a bad idea for A4's too. Lugging the motor is probably what caused the backfires, which can be caused by spraying at too low of an rpm.
Old May 19, 2005 | 12:55 PM
TNTramair's Avatar
keep the spray in the high r's and you'll be fine with backfiring...but you need a window switch for safety sake. i recommend a timing tuner..excellent piece.!!
Old May 19, 2005 | 03:17 PM
ls1charged's Avatar
you dont need 1 but if your not too sure of yourself on shifts or have ever missed a shift then its not a bad idea.
Old May 20, 2005 | 04:44 PM
vince3's Avatar
i had a digital 6 with my lt1 car, but they dont work for ls1's
do they make a cheap one? might not need it running a 100 shot
Old May 20, 2005 | 06:26 PM
TonyJ's Avatar
Shifting shouldn't turn off the nitrous with the window switch unless your RPMs drop below 3000 (or whatever you have your in point set at...) The WOT switch will shut off the nitrous when you lift your foot. That's what you need, IMO...
