Spark Plugs
Old May 24, 2005 | 08:43 AM
Silver 00 SS's Avatar
Default Spark Plugs
When do u change out your spark plugs, Once a year, Two years..... i got a 150 shot and use a 10 lbs bottle every 3 weeks........
Scott
Old May 24, 2005 | 08:52 AM
99SilverZ's Avatar
Normally you should check them once a year at least. That's under normal driving. Using the bottle often, you should check them more often than that.
Old May 24, 2005 | 09:24 AM
next's Avatar
I change mine around 8-10 passes and that was running a 175 shot.
Old May 24, 2005 | 09:31 AM
NXJeremy's Avatar
My car was a my daily, plus used it at the track. So I changed mine usually every other trip to the track. This was probably every 15 passes or so, with lot's of daily driving.
