100 shot hits week
Old May 29, 2005 | 11:42 AM
96KillaZ's Avatar
Default 100 shot hits weak
My 100 shot feels very slugish, Does anybody have any suggestions, by the way, this is a wet kit... Thanks
Old May 29, 2005 | 02:31 PM
2MuchNos93LT1's Avatar
make sure your nitrous line is not by anything hot. make sure your line is not kinked make sure the bottle is a 100% full double check your jettings.
Old May 29, 2005 | 03:35 PM
Tiger2o69's Avatar
Do you know your a/f ratio? What type of kit is this?
Old May 29, 2005 | 03:51 PM
Turo's Avatar
Get it dynoed, it could just be that it feels weak to you, but in reality its just fine. Just a thought, good luck!
Old May 29, 2005 | 03:53 PM
CarsRFun's Avatar
weak...
Old May 29, 2005 | 04:23 PM
96KillaZ's Avatar
My nitrous line is routed under my carpet, but my nitrous and fuel solonoids are bolted above my intake manifold which is pretty hot, could that be the problem? Also my air/fuel ration is around 12.5 without the nitrous.
Old May 29, 2005 | 06:56 PM
TS6's Avatar
TS6
What is the bottle psi and the a/f ON the bottle?
Old May 29, 2005 | 08:21 PM
96KillaZ's Avatar
I dont know the air/fuel and I dont have a gauge for the psi yet on the bottle, I just ordered the dynotune bottle warmer today. Does the psi make that big of a difference? That might be my problem
Old May 29, 2005 | 09:07 PM
TS6's Avatar
TS6
Oh yeah, it'll make all the difference. Its been in the 70's here and my bottle psi has only been 800 or so. Thats why I have a heater.
Old May 29, 2005 | 09:09 PM
Turo's Avatar
It's been in the 90's here, I almost don't even need a bottle heater
Old May 31, 2005 | 02:35 AM
bhz28's Avatar
check your N20 jets I had that problem and I looked in my jets holding them up to light ndone was clogged, cleaned it nd it was a big difference
Old May 31, 2005 | 03:46 AM
ITLstallion04's Avatar
bottle warmer? are you 100% positive it has the 100 shot jets, and not the 75? Just things to look at..
Old May 31, 2005 | 10:35 AM
BadAssFast's Avatar
check everything as stated above...i went from a 75>100>125 and now use a 150 shot. the perceived difference (to me) is exponential...75 to 100 seamed week my current 150 shot is a blast.
Old May 31, 2005 | 01:15 PM
Deckhand's Avatar
make sure your nitrous and fuel jets arnt swapped.
Old May 31, 2005 | 06:36 PM
hondo's Avatar
try it next WEEK
put it on a dyno with a wideband and spray it, you'll know real quick whats happening
