Pic of your Bottle Set up
Old Jun 8, 2005 | 10:05 AM
TOZ's Avatar
TOZ
Default Pic of your Bottle Set up
Please put a pic to see the way you set up your bottle in the car. Need to get ideas. I got mine on the back of my rear seat but Moroso does not approve it.
Old Jun 8, 2005 | 10:24 AM
02 Pewter LS1's Avatar
Here is mine with the panel off pictures were taken awhile ago.
Old Jun 8, 2005 | 10:34 AM
aNuBiS's Avatar
Default trunk
spare tire compartment
Old Jun 8, 2005 | 11:27 AM
N20LT4Bird's Avatar
Ive got mine mounted between the two back seats........sitting right next to my son's car seat! I dont need a remote valve; I just reach back and crack it open. (not with him in the car, of course) I dont see why this is a problem. Ive got the blow down tube exiting through the floor. It doesnt matter where you put it on an f-body, its still going to be in the passenger compartment. Ive never had a problem at a tech inspection.
Old Jun 8, 2005 | 11:39 AM
calongo_SS's Avatar
I've got mine behind the drivers seat angled towards the center a touch. I didn't want to buy an opener, and I didn't wan to tear up the carpet too bad. This way I can put the seat back in and you'll never know it was there.
Old Jun 8, 2005 | 12:02 PM
LS69TA's Avatar
On my 02 Z, I had it on the rear deck, where the child seat anchors are ( I think that's what they are). Took the pass. side one off, and mounted the bottle bracket there using the bolt for the seat anchor, and angled it towards the drivers side..roughly 45 degrees, and had the bottom resting on the fold-up divider. Worked good for me. But it was in direct sunlight..which wasn't too great here in Tx.
Old Jun 8, 2005 | 12:12 PM
mrr23's Avatar
close the trunk and keep the cover closed, you can't see them. so, unless they make you open the trunk and hood, they won't ask. technically, i need straps and blowdown tubes to make it track legal.
Old Jun 8, 2005 | 05:01 PM
TRYTHSS's Avatar
the most popular place......spare tire compartment.
Old Jun 8, 2005 | 05:14 PM
MetallicaMatt's Avatar
i have a question with that set up
don't you normally want the bottle angled? like the rest of the pic's?
Old Jun 8, 2005 | 05:21 PM
150shotWS6's Avatar
Between Back Seats!
Old Jun 8, 2005 | 09:48 PM
daryl2cb@yahoo.com's Avatar
http://www.organ1zedcha0s.com/phpBB2/viewtopic.php?t=10 here is a link to pic of my whole set up, the pics are old, as there are new goodies on my car now, and lots of removed things like egr, air ect, but it will give you the basic idea.
Old Jun 8, 2005 | 10:14 PM
TRYTHSS's Avatar
it does not have to angled,
Old Jun 8, 2005 | 10:47 PM
Kolk1's Avatar
15lb bottle
Old Jun 8, 2005 | 11:08 PM
2002yroneformula's Avatar
He has a nitrogen push system I believe, so unless I'm mistaken it doesn't really matter.
Old Jun 9, 2005 | 09:21 AM
Nitro Dave's Nitrous Outlet's Avatar
You can sit the bottles upright if you make the needed changes.Inside the bottle there is a pick up tube.This pick up tube has a angle on the bottom putting the pick up the same direction as the valve.If you stand them up you will need to take the valve out of the bottle and twist the pick up tube facing back.The other direction.This way as the G forces come in pushing the nitrous to the back side of the tank it can still pick it up with out having air pockets.
Dave
Old Jun 9, 2005 | 09:43 AM
fstphx's Avatar
so its there a reason you cant turn the bottle the same direction as the valve ( or whatever way puts the tube to the back) and not remove the valve, this wiould really simplify my install.
Old Jun 9, 2005 | 02:13 PM
Ouija's Avatar
Old Jun 9, 2005 | 03:45 PM
DaBigJC's Avatar
http://www.fearno5.0.cz28.com/photo2.html
it's like the thid pic down.
Old Jun 9, 2005 | 07:06 PM
mrr23's Avatar
it has a slight angle forward. in talking with enough nitrous people, this is the better set up. the tube will never become uncovered. i've seen too many instances when the bottle is about half empty that people having them inbetween the back seat on the driveshaft hump start having problem. mainly due to the fact the bottle bracket aren't angled enough to sit on a downward angled surface like the driveshaft hump is. i've done the spare tirewell on my 94 z28 i had. but, what do you do when you have flat tire?????
Old Jun 9, 2005 | 07:30 PM
fix a flat? lol
