Dip in nitrous dyno caused by what?
Are you heading tothe dyno again soon?
Good luck and let me know what it was so i can fix my car too!!!!
Scott
THats not to say you may have something defective in your stock setup...like the regulator. But if everything is working properly....650 rwhp+ should be a breeze. Same with a sustained TQ of 650+.
Just buy some NGK TR6 plugs...gap at .030 and redyno. Check all you plug wires for good contacts and connections as well as your coil pack harnes to be sure its seated etc. At your Tq level you should not be having that dip. I am still going with plugs.
If Patrick can run again with a wideband and get an AF he should be able to determine wether it is fuel or spark.
The car never went lean, they go rich, from the system being a "return less" system and having the regulator located in the tank, above the pump. I'll try to dig up the graph with the A/F, but I agree 100% with ya, if Patrick can get back on the dyno with a wideband he will know if it's the fuel system causing him to go real rich for a few hundred RPMs.
I have personally been involved with atleast 10 cars that dynoed in the 500+ range. And 3 that went into the 700 rwhp range with stock fuel systems excpt for Walbro intank pumps with hotwire kits. This is stock regulator, stock rails, stock feed line from back to front.
I just cant see the regulator being a problem at 500 hp mark. Unless maybe you had the stock pump. But in any event it seems like it would be a lean spike.
we have seen so many 500-600 rwhp stock fuel system cars here in tampa its not funny. rich = dip in the power curve, not lean. the only issue is the lean spike from the stock fuel pump not being able to keep up, but thats on the initial hit of the nitrous.
"Dropping pressure is due to the lack of regulation at the fuel rail. If the return line was at the rail then pressure would be stable.
In other words the problem is with the position of the regulator in the LS1.
Q. If the pressure is stable at the back of the car under W.O.T. (58PSI) where the regulator is in an F-LS1 but the pressure drops at the fuel rail due to line drop WHERE do you suppose the problem is?
Q. Why don't '97 C5's with front-mounted FPR's experience the same level rail pressure loss as compared to later model C5's or F-LS1 cars with rear-mounted FPR's?
Q. How can the regulator adjust for line pressure drop (by backing up the feed line to the point of pressure relief at 58PSI) if it is located at the back of the car where the line drop is not occurring?
Go plumb a pressure gauge into the back of an F-LS1 car which has rail pressure drop and come back and tell us what you find!
Then relocate the regulator at the front of the car with a return line without upgrading the feedline and you will find that the pressure is stable which indicates adequate volume.
So in conclusion if you want to save a more than a few bucks relocate your regulator to the end of the fuel rail with a return line!!!"
Right, the car will go lean very quickly & shortly after the fuel solenoid is opened up when using a FPR in the stock location. With a FR mounted FPR you will not see that pressure drop, and the car won't go lean.
Now, back to my point, with the FPR being located in the rear how is it to keep a stable fuel pressure at the rail? It can't. The regulator is at the back of the car and the pressure drop is happening at the fuel rail.
I still believe Patrick G 's problem is fuel pressure based, and it is causing him to go rich and lose power. Attached is the dyno graph from above with the A/F chart.
If your saying it will go very lean at first...then surge back to rich....thats another story. But if thats the case that 11 to 1 your graph is showing will not cause such a SHARP loss of power without dropping a cylinder momentarily.
Your dyno graph definately shows rich...but not so rich that it should cause THAT amount of rapid power loss. As a matter of fact the AF is all over the place...but that dip in HP is really the ONLY huge spike in power loss. I mean a 75 shot is not that much power and not that huge of a shock.
Im just not seeing it.
My logic is this: Upon the fuel solenoid opening there is fast lean condition (lean conditions usually show a spike in power). To compensate for this lean condition the FPR over adjusts by sending too much fuel (usually causing a dip in power). This cycle continues through out the RPM range, over and over and over again which is seen in the A/F. Since there was not a wideband used no one can tell. From our experience this has been the culprit, with the solution being a FPR located on or near the fuel rails with a return. Considering the lower horsepower levels in this example it could also be ignition related and as stated earlier nobody will know until there is a dyno pull with wideband present.
Anyways...Patrick...get back on the dyno and let us know.
