Fuel Pressure Safty Switch.
Old Jun 13, 2005 | 07:01 PM
meanls1's Avatar
Default Fuel Pressure Safty Switch.
Is this a good Idea? I'm hearing mixed comments about them. I do have a racetronix pump and 36# injectors.
Old Jun 13, 2005 | 07:37 PM
Texas Terminator's Avatar
if you loose fuel and keep spraying NOS, well,...........BOOM! so, doesn't hurt. weigh the cost of the safety switch against the new motor.
Old Jun 13, 2005 | 08:35 PM
Robert56's Avatar
Some like, some don't. I run one for the safety factor. The guys usually having problems don't have them adjusted correctly.
Old Jun 13, 2005 | 08:37 PM
DynotuneN2O's Avatar
LS1TECH Sponsor
You can never be too safe
http://www.dynotunenitrous.com/store...?idproduct=135
Dean
Old Jun 14, 2005 | 01:55 AM
150shotWS6's Avatar
They don't seem reliable! I hear nothing but bad about them!
Old Jun 14, 2005 | 08:59 AM
NXRICKY's Avatar
Closed ex-Sponsor Account
Run 2 one before and one after the fuel noid for the ultimate in safety.
Ricky
Old Jun 14, 2005 | 09:25 AM
NXJeremy's Avatar
I would say definately run one. The majority of the negative comments about them are due to them being improperly adjusted. Anything that makes the system a little safer is good IMO.
Old Jun 14, 2005 | 06:58 PM
meanls1's Avatar
I didn't know they were adjustable.
Old Jun 14, 2005 | 06:59 PM
Racetronix's Avatar
LS1TECH Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Good idea. Use a Hobbs brand switch.
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Old Jun 14, 2005 | 08:12 PM
Robert56's Avatar
Yep, you can adjust for the pressure you want it to shut your system down. Some are to high from factory and cause problems from the get go.
Old Jun 14, 2005 | 08:18 PM
calongo_SS's Avatar
Ricky
This sounds like a good idea. Should both of them have the same setting. I have one now, and it's set at 50 psi. Should the one after the noid be set the same?
Old Jun 14, 2005 | 09:32 PM
meanls1's Avatar
http://store1.yimg.com/I/whitespitstop_1846_95737819
How do you adjust them?
Old Jun 15, 2005 | 08:48 AM
NXRICKY's Avatar
No The one after the noid should only need to be low pressure, lets say 3-5 psi. You do not want that line to see full pressure and then turn the nitrous noid on, that would give you a bog,or overly rich condition for a moment.
Theres and old link from some tech tips I did. I think there is some drawing in there to.
https://ls1tech.com/forums/showthrea...light=tech+tip
The FPSS is adjustable. On the topside of the switch there is a rubber plug. Removing this plug and you will expose a hex type screw. Tuning the screw clockwise will raise the set point. Counterclockwise will lower the set point. Normally there is no need to adjust these switches they come from the factory preset. WARNING: setting the FPSS to close to the operating fuel pressure of your system will cause the nitrous system to bounce, chatter or go on off really fast. And setting to far away will not do you much good.
Hope this helps
Ricky
