How much spray are you getting away with on stock LS1 bottom ends?
Old 06-23-2005, 07:34 PM
12 Second Truck Club
Magic Chicken's Avatar
Originally Posted by 1QuickT-A
Anybody tried running a WET 150hp shot on stock fuel pump? I've got a Walbro 255 on its way but I've got a match race lined up for Saturday night. If the pump doesnt get here by tomorrow I'm screwed.. My car is stock longblock with all the bolt ons and full suspension. I'll be running 110 octane with timing at 27-28 degrees.. Will it hold if I have to run with the stock pump?
I run 175 wet on stock truck fuel system. I'd think the car fuel system would be able to handle it better than the truck system.
Old 06-23-2005, 07:48 PM
Robert56's Avatar
185 currently and 200past with stock fuel pump. The vette pumps can take a little more hp before maxed out though. The general rule, about 450hp f-body and 550+ on the vette. I know guys go past this, but it may be taking a chance.
Old 06-23-2005, 07:50 PM
Just curious, who comes up with this stuff?
Old 06-23-2005, 08:03 PM
Robert56's Avatar
Well it's well known on the corvetteforum.com that the stock walbro pump will easly support 550hp and many guys go as far as 600plus, can check it out in the forced induction/n2o section, many, many posts on this ( and experiance). As far as the f-body, I just go by what the guys have been reporting on this site for some time (that's why I said about, not totally sure).
Old 06-23-2005, 08:44 PM
blkZ28spt's Avatar
That's about how much the injectors can handle. Little lower for a 99-00 than the other years.
Old 06-24-2005, 02:01 AM
LS1_PNYTAMR's Avatar
i was spraying 150rwhp tnt wet kit shot which is the hardest hitting shot of its kind imo.. on the stock fuel system right down to the pump trapping 122.8 with lid cutout and nittos on a otherwise stock car..
i dont know how i would hoook up a progressive thing or where to find them.. only ones i see in jegs look for oldschool motors ect.. can someone fill be in on this.. im upgrading a 255 pumpa nd thats it.. i dont really see why u upgrade injectors for a wet kit???
Old 06-24-2005, 02:57 AM
Restricted User
CAT3's Avatar
Injector has **** to do with it for Wet kits, nothing. As far as spraying 150 shot on stock pump, sure, but not with other mods, which is were a lot of ppl run into problems. You look and see someone is running a 150 shot, and say ****, I can do it too, difference they have only a couple mods and your H/C etc....
Anyone have the part # for the stock vette and f body pumps you should be able to cross reference them and see the flow difference, personally I dont care, swap it out and spray away.
I have run the NXL jetted at 220 stock bottom and cam only. No issues other than a clogged filter.
Old 06-24-2005, 03:02 AM
Restricted User
CAT3's Avatar
Are you saying you have 185 jet pattern or you have it jetted to 200 (Sig) and it puts out 185 on the rollers? Always thought posting gains instead of jetting was
Old 06-24-2005, 03:19 AM
v8-7's Avatar
honestly is it that big of a deal? Whats a new intank pump cost? $150 max?
i have the aeromotive a-1000 supports 800 or some BS RWHP on EFI... But i have a different pump for the juice unit.
Old 06-24-2005, 06:20 AM
DopeFedZ's Avatar
We've done 300 on a stock block before.
Old 06-24-2005, 08:13 AM
WS6snake-eater's Avatar
Originally Posted by Navy David SS
You should be fine shooting out of the hole as long as you have the suspension and tires. Watch out for the stars - they are great to look at, hurt like hell on the way down Expect one hell of a ride. --you don't say type of tranny - shift fast - real fast I try to keep the bottle over 1000-1100. With the 150, I am running 28 degrees of time on 114 race gas. -- the gas prevents detonation not more hp.
David
Is the 114 in the tank, or do you have a standalone system?
Old 06-24-2005, 12:00 PM
  #32
Robert56's Avatar
I use the conversion factor for the NOS dual nozzle to rwhp. So, in first stage I have 85rwhp (100hp jets) in 1st gear, then in second gear at 4600rpm (as of last night for drags tonight) comes 65rwhp (or 75at crank). I think I'll just remove the hp in my sig until I get my drive train set up, but have sprayed with the 200 a few times. The vettes are famous for busting the gear/trans cases and half shafts with to much torque hooking up, not to mention I'm still on stock clutch.
Old 06-24-2005, 02:33 PM
  #33
Navy David SS's Avatar
WS6snake-eater. In the tank. I don't run a stand-alone system. So far so good. I don't run many N/A passes. I would assume the 114 would really kill my times. Oh well.
David
Old 06-24-2005, 02:44 PM
  #34
blkZ28spt's Avatar
CAT3, pleas follow this line of questions, and you'll see why I said what I did.
First question:
Magic chicken quotes part of above question and asks:
I answer with:
That whole line is referring to injectors. I realize that it doesn't mean anything for wet kits, hopefully others do too, but apparently they don't.
If I was thinking I would have pointed out that it was pointless for people to say they are sparying XXX wet kit on stock fuel system, because the stock fuel system doesn't have to supply the extra fuel.
Old 06-24-2005, 05:51 PM
  #35
Restricted User
CAT3's Avatar
First question:
I answer with:
*MENTAL NOTE* blkZ28spt and I are referring to Dedicated Wet Kits(stand alone fuel cell), where as the fuel pump is only providing the NA HP. On traditional wet kits, the fuel pump is a major NEED item. The stock fuel pump, although proven to go beyond 450rwhp, is not recommended as when the activation occurs, it draws a large amount of fuel from the STOCK rails (or aftermarket), and the design of the STOCK system causes a lean condition on the drivers side, where the wet kit taps off the STOCK rail. But agree'd most ppl should already have that part down, but most tend to skip the stickies at top, the Colonels Nitrous Tech Files and that invaluable Search button.
Old 06-24-2005, 06:12 PM
  #36
blkZ28spt's Avatar
And the scenario you list is why people seem to lose the #7 cylinder more than any other.
Stickies and the search button have SO much information to offer.
Good explanation there.
Old 06-24-2005, 06:30 PM
  #37
1QuickT-A's Avatar
Well I'm gonna be spraying a 150 shot tomorrow night on the stock fuel pump.. Car has all the bolt ons with 110k miles! Id rather blow the mother ****** up then lose to this ProCharged Mach1..
Old 06-24-2005, 06:41 PM
  #38
blkZ28spt's Avatar
According to your sig you have heads/cam too....
Old 06-24-2005, 09:59 PM
  #39
mrr23's Avatar
links in sig
00 formula 200 on completely stock motor, fuel system, and programming.
99 formula 175 with most bolt ons and heads with stock fuel system and programming.
both are wet kits.
Old 06-25-2005, 01:42 AM
  #40
1QuickT-A's Avatar
If you look closely it says "some parts not yet installed"... I just picked up the heads/cam package from Gomer last week.. Im waiting to get my trans rebuilt so I can put the heads/cam on..
Quick Reply: How much spray are you getting away with on stock LS1 bottom ends?
