MSD Window Switch into shift light???
Old Jun 24, 2005 | 05:46 PM
Insanekamel's Avatar
Default MSD Window Switch into shift light???
Is there anyway I can make a Msd window switch (w/plug) light up an Led as i hit the shut off rpm's? I'm too cheap to buy a shift light and have some red led's laying around. Thanks
-Steve-
Old Jun 24, 2005 | 06:10 PM
Airwolf's Avatar
The problem with trying to do a simple circuit that way is it would be "on" when the window switch was not active, meaning at idle! The window switch is turning items off below and above the active range so I do not think a simple circuit would know the difference.
Old Jun 25, 2005 | 07:59 AM
BMN's Avatar
BMN
Nope, like said above. Would be on from idle to 3K then from 6K up.
