Does compressed air have weight?
I just wanted to make sure I wasnt the idiot..
So will 10lbs of air go in the bottle or is it less than that?
plus the only way of getting air to have weight is to compress it into a liquid.
you cannot put 10 lbs of air into an aluminum nitrous bottle and not have it blow up in your face...the pressure would be so extreme.
Ricky
Ricky
show that to the guy. also do what we do. put the bottle in a cooler filled with ice water, and remember, the slower you fill it, the less the bottle will heat up Ricky
This is also why cars that have pusher system do not run rich on the big end or at the end of the bottle. They are offsetting the boiling by adding nitrogen to the topside of the liquid inside the bottle.
Ricky
Whats the best size bottle to use so you can get the most of what you have? 5 10 15? Seems like a 5lb bottle would be best and get worse as you go up.
I do keep my bottle in the freezer then put it in a cooler of ice to get the max in the bottle. This last time he told me he would put a vacuum on the bottle to clean it out and then I could definetly get 10lbs of good nitrous.
I searched again but found nothing on the vacuum as well. He said I should do it to my bottle every once in a while and charged $10 extra for this. Is this something you recommend and how often? Thanks for the help.
This isnt the place where the issue is happening however.. I stopped going there and started going to this guy and told him my problem. He said it was normal but I have ran nitrous for 6 months now and never had this problem. Normally I can tell the pressure goes down but I still get a good bit of hp out of the run. With this last 2 bottles that have had the vapor in them I get nothing. At 19lbs last time I only went rich and lost time. Usually I can start a 1/4 run w/ 17 in it and pick up 8 tenths in the 1/4. With a full bottle I get 1 to 1.1 seconds off my 1/4 time.
The other place uses a nos pump and the other guy uses a nx pump so maybe thats why the other guy gets more vapor at the end of the bottle. Or one of them doesnt let it run down as bad.
so you could not put 10 lbs of air into a nitrous bottle and have the seal disc not rupture from teh pressure.
