Dynotune Purge having issues
Old Jun 30, 2005 | 06:17 PM
Tiger2o69's Avatar
Default Dynotune Purge having issues
Sometimes it works right and other times it will slowly let air out. I checked the wirring and its ok. I also checked for something stuck in it and I can find anything. Any ideas what whats wrong w/ it?
Dan do you have a warranty on these?
Old Jun 30, 2005 | 06:33 PM
LETZ RUN's Avatar
check the volts.. maybe its not getting enough volts to completely open the noid? do you hear the noid click?
Old Jun 30, 2005 | 07:13 PM
Tiger2o69's Avatar
Yeah it clicks and lets a little air out. I hooked it straight to the battery and its still the same.
Old Jun 30, 2005 | 07:34 PM
LETZ RUN's Avatar
is your bottle at an ungodly psi and the noid cant open fully?
Old Jun 30, 2005 | 08:20 PM
DynotuneN2O's Avatar
LS1TECH Sponsor
Tiger,
If it is still acting up - We will be glad to check it out on the bench for you. I will PM you our address for returns. We warranty all our products so no need to worry!
Dean
Old Jul 1, 2005 | 02:16 AM
Tiger2o69's Avatar
Thanks Dean I got to pick up some more stuff from you guys while im at it. Always good to deal with
