Not enough?
Old Jun 30, 2005 | 06:49 PM
99ta's Avatar
Question Not enough?
I just recently dynoed my car (mods in sig) it made 400 HP N/A and only picked up 75 HP on a dry 125 shot (52 jet). I have a small NOS noid and a single nozzle thru the filter. Could it be placement, is only nozzle enough? The car is tuned and the A/F was good on the motor and the gas(not sure what it was but was told it was good). Does anyone think I should go with a wet shot, would it even help? Thanks in advance for any help!!!
Old Jul 1, 2005 | 09:00 AM
99ta's Avatar
T T T
Old Jul 1, 2005 | 09:05 AM
jamnut's Avatar
Bottle Heater? Bottle pressure? Need some more information.
Old Jul 1, 2005 | 09:18 AM
Noyzee's Avatar
8 second mod
yhea, sounds like the bottle may be low. you can have no jet, with low press, its never going to make the "125" hp.
Old Jul 1, 2005 | 09:38 AM
Z284U2TRY's Avatar
I bet its your injectors. My car made the numbers in sig on dry shot 28.8 inj. Thats all the injector I have is good for. 125 engine hp jetting with assuming bottle psi and everything else was on par will net a solid 100rw
Old Jul 1, 2005 | 10:00 AM
Bryan @ Speed Inc.'s Avatar
you were in GMhigh tech mag. right???
Old Jul 1, 2005 | 10:14 AM
Noyzee's Avatar
8 second mod
yes.
but that was when i had twin turbo setup
Old Jul 1, 2005 | 10:21 AM
Ravenous T\A's Avatar
Could it be the NOS jetting? dont they rate there stuff at the Flywheel?
Old Jul 1, 2005 | 10:44 AM
yes.
yea what happened??? didn't like the turbos???
regardless you car rocks (ed)
Old Jul 1, 2005 | 11:05 AM
Noyzee's Avatar
8 second mod
nos does do that, but it should make more then that, i would think a 100 shot would make atleast 80 to the wheels.
imslow. i loved the turbos, but the kit i had just wouldnt do what i wanted, and i was tring stuff like most people wernt, kind of uncharted territory, and it was hard.
so i figured time for a change.
thanks
Old Jul 2, 2005 | 03:57 AM
99ta's Avatar
Bottle was right over 1000 psi. I thought it would make about 100 HP was looking for 500 rwhp on the gas. Also I do have the 28.8# injectors and it is tuned for them.
Old Jul 2, 2005 | 07:38 AM
koolrayz's Avatar
You said the A/F was good on the dyno but you need to know what exactly was it. I found it made all the difference in the world running the A/F below 12 with a dry shot even a small one. when i was running my 5177 kit it was like night and day. did you log for KR?
