need help with timer
Old Jul 7, 2005 | 03:50 PM
pushinfreight's Avatar
Default need help with timer
I am installing a two stage dry setup and have a Digi timer from Nos to delay stage one. I want to be able to get through most of the 60' and not blow the tires off. This Digi timer allows me to delay the activation of the N02 in tenths of second intervals. I will have a wot switch, window switch, timer and relay to all wire together. I would think that you would need to put the timer between the window switch and the relay. Does anyone have any ideas on the matter?
Old Jul 7, 2005 | 05:51 PM
Robert56's Avatar
Check with NX Ricky, as He is the wiring guru around here. Yea, I should have done what your doing maybe my stock clutch would still be ok, but no, I had to spray outa the hole and 2nd stg ***** out, hello Textraila.
Old Jul 9, 2005 | 09:24 AM
anyone else have an idea?
