Does anyone have the MSD Digital Window Switch?
Old Jul 11, 2005 | 04:49 PM
00RedWs6's Avatar
Default Does anyone have the MSD Digital Window Switch?
If so how do you like it? I was looking into these but have never dealt with one. All the other window switches Ive dealt with have had the pills. Anyways just lemme know if anyone uses this and how you like it. Thanks
Brian
Old Jul 11, 2005 | 05:26 PM
150shotWS6's Avatar
Old Jul 11, 2005 | 06:15 PM
Race Car Driver's Avatar
11 & 7 Second Clubs
Yes, I have it, but I only use it to start the NO2 and I now spray through the shifts.
Old Jul 11, 2005 | 06:38 PM
NOSjohn's Avatar
Restricted User
Works good and a little easier to set up I guess. We just put one on a Z06.
Old Jul 11, 2005 | 09:45 PM
code4's Avatar
I love mine I bought from dynotune, I can change on/off rpms in seconds even while I am driving down the road. I can also set it to 200 rpm's so I can test the system while the car is idling (nitrous unhooked of course) When you turn it on it gives the on/off rpms each time so you know it is set correctly. After it displays these on/off rpms it reads your engine rpm. I have mine in the console, I had to remove a little material where cd's go.
Old Jul 11, 2005 | 10:37 PM
RUTAN TA's Avatar
I love mine b/c I dont have to carry pills and can adjust easily to help dial the car for track conditions
Old Jul 21, 2005 | 08:42 PM
frey51's Avatar
Are the digital window switches easier to hook up than the old pill style? because I know of other people having activation problems with the pill type, and I cant seem to get mine to work even though the system was working correctly before the window switch install (and I followed all the directions to a 'T'). I am thinking of getting this if it will solve my problems.
Old Jul 21, 2005 | 08:48 PM
NOSjohn's Avatar
Restricted User
I am 98% sure they use the same wires/wiring scheme.
Old Jul 21, 2005 | 09:39 PM
frey51's Avatar
I traded my stock gears for the pill w/s I currently have, and I think that it may be faulty as I have it hooked up according to the wiring guide on the NX site.
Old Jul 21, 2005 | 10:01 PM
11 & 7 Second Clubs
Just returned my DWS to MSD this week because it would not work while the analog unit will work. ??
Old Jul 21, 2005 | 10:13 PM
setxws6's Avatar
Mine has worked like a charm since I installed it. I've had my system working for a little less than a month now. I love how you can change the on and off setting in about 5 sec. It is a little bit bigger in size though, so if you put it under the hood, you have to worry about clearance and where to put it.
