Will a 100 dry shot max out stock injectors on a 98 Z28?
I will be spraying 100 dry shot. Ive been told that the 98s have the bigger injectors at 28lbs and a lil bigger fuel pump to. With a bolt on car will the 100 dry shot max them out or will I be ok? Boltons that are on it are Lid,LT's Y pipe and catback exhaust system. Will I be ok or do I need to look into 30lb since they arent very expensive anyways from MTI? Any info is appreciated. I will put it on the dyno to make sure everything is ok.
Brian
Brian
my 100 shot maxxed out my 26lb injectors and my car was pretty much stock at the time. You already have 428rwhp so go with some 42lb'ers, you can find FMS 42lbs on ebay for 250 shipping included.
Brian
Brian
That being said. I also think that it's not a problem.
