(FPSS) Fuel Pressure Safety Switch Are they GOOD?
#41
Originally Posted by N2RACINGLS1's
I just read this entire thread. No one talked about how you correctly adjust a FPSS. Let me start off by saying I want to use my FPSS!!!
I posted before on my 5177 dry kit with problems on the FPSS. Before this year the system worked perfect for three years then stopped working. I could get it to work at home in the driveway but not at the race track then three weeks ago I was told to adjust the FPSS. I adjusted the FPSS a half turn counter clockwise and the system worked but sputter a little. I than adjusted another half turn counter clockwise and the NOS system worked perfect.
I go back to the track yesterday with 900 PSI and the system worked perfect on the first NOS pass then started to sputter on the second pass.
I am only using a 75 HP on a 98 stock motor with stock injectors. I have installed a 2002 plastic tank though. The car ran 7.72 at 87.71 MPH NA and than 7.32 at 91.87 MPH on the NOS.
Any thoughts?
Any thoughts?
Unless you have a bad FPSS, it sounds like your fuel system is on a downward spiral if you have to keep going counter clockwise on setting (lowers set point). Could be a weak pump going out, a clogged filter ect. But checking set pressure and seeing if FPSS works fine will tell ya which way to go/look.
I think NX sends their sws set at 35psi to cover a multitude of cars. Myself, a drop of more than 5lbs from our 58psi means inadequate fuel system or problems. But others will say 10lbs or so.
Hey guys, sorry about being so grotchy early on in this post ('05), that was when I was dealing with my neck injury just before surgery, and the pain pills tend to make one more of an *** than normal.
Robert
#42
Like said above, if you ran a FPSS on the outlet side of the solenoid, the system would never fire, unless you had the FPSS on a switch to disable it until after the solenoid is open, but then every time you shift, you will be back to the same thing. This could be remedied if you were to use some sort of a time delay where the FPSS signal would not be used until a desired time after the solenoid powers up, or something along those lines.
If you don't run a time delay, the the FPSS won't see pressure in the line until the solenoid opens, but the purpose of the FPSS is to not let the solenoids open unless there is adequate pressure.
A way around this I guess would be to use the pre-solenoid FPSS to control the entire system, and the post-solenoid FPSS to control only the nitrous solenoid. This way, the fuel solenoid opens, FPSS sees pressure, and allows the N2O solenoid to open. I imagine by the time the fuel at 58psi reaches the nozzle(s), the 950psi nitrous should be able to make up the small time delay.
The other idea would be to use a pre-solenoid FPSS and a pre-solenoid flow meter, but I'm unaware of how cheap and readily available a suitable meter would be.
#43
Robert
#44
Originally Posted by Robert56@NitrousDirect
You can use a signal, that would be present anytime you go wot. Then if there is pressure it'll be closed (contacts) and allowing fuel to flow. So like you said, one FPSS before noid as per normal, then one after that's controlled seperately. I guess some testing would be in order. Would this slow the fuel down and cause a lean spike, and thus the need for a time delay on nitrous side?
Robert
Robert
In fact, it might even make the initial hit safer whereas with a normal setup, I imagine the nitrous gets to the nozzle slightly before the fuel does anyways (950psi air vs. 58psi liquid).
#45
Or like I said, have the fuel solenoid activated by the system as normal, but use the post-solenoid FPSS to control the nitrous. So the fuel solenoid needs to open, and the post-solenoid FPSS sees a pressure, then the nitrous solenoid opens. So the fuel solenoid would be opening slightly before the nitrous solenoid, which wouldn't cause a lean spike at all.
Robert
#46
Well, the pre-solenoid FPSS would control the entire system, just as normal. If a fuel pressure drop occurs, everything is shut-down as usual.
The post-solenoid FPSS would only control the N2O solenoid. Really, there is no need for it to control the fuel solenoid. If there isn't any flow after the fuel solenoid, there is no need to turn it off. Even if it is clogged and letting some fuel still (but not enough to make the post-solenoid FPSS enable the nitrous solenoid), worst case is you'll run a little rich.
The post solenoid FPSS would only control the nitrous solenoid. If the fuel solenoid is flowing properly, the nitrous solenoid will be activated. If the fuel solenoid is not flowing properly, the nitrous solenoid will not be activated.
#47
#48
Originally Posted by lak8
Danm yea, i think that would work great. Only problem i can see with this is a little rich at frist but.... like you say the N20 is at what 900+psi and fuel maybe 50psi so it probably wont even be a problem. Even now that i think of it i bet a standard wet setup is super lean for the split second when the nitrous is activated.
#50
Something i was thinking of that might go wrong is... how long does it take for a FPSS to sence pressure and turn on (or maybe someone knows how long it take to sence no pressure and turn off).
This may be a problem since if it takes about 2sec or more it would be dumping in fuel with out the n20. this will couse a super rich situation and might get a intake backfire. If it senses pressure instantly i cant see a flaw in this DuronClocker and i think it would only help out more since im almost sure n2o reaches the nozzle before the fuel (this would probably be a split second but still) and this would be a big saftey feature in saving your engine from a faulty fuel noid not opening.
#51
Yeah, I believe I mentioned that in one of my first posts in this thread that they may not react quick enough. If I didn't, I meant to as it was one of the first things that popped into my head.
I also noticed in a few threads where people said their AFR at the initial hit was 12.9-13.1, but leveled out at 12.5-12.6. So it seems like the nitrous does in fact get there before the fuel does normally.
We need to know how quick these sensors react. Anyone want to go out and test it? Floor the car and hit the ARM switch once you're already WOT and see how instant the nitrous hits. If it feels pretty instant, then there shouldn't be a flaw in this design. If it feels like there is lag time between hitting the ARM switch and the nitrous actually activating, then this idea will not work without a more complicated (and expensive!) time delay setup.
