dry nitrous
Old Jul 26, 2005 | 01:19 AM
mxmccarter2401's Avatar
Default dry nitrous
So correct me if im wrong. To spray nitrous dry all i need is to put a dry nozzle anywhere in front of the maf. Don't need to mess with the fuel pressure regulator. I just let the maf add the additional fuel? sounds too easy. thanks for your help.
Old Jul 26, 2005 | 01:22 AM
JustAnIlluzion's Avatar
yes its that simple.
Old Jul 26, 2005 | 03:20 AM
keeven1320's Avatar
will the maf read dif amounts of n2o? or will it run rich/lean untill u have the correct amout of n2o?
Old Jul 26, 2005 | 06:33 AM
GM Muscle's Avatar
The MAF will add the nessesary amount of fuel for the size of the shot. On a bolt on only car you will be running out of injector at about a 125 shot.
