Zex Wet Kit Promble
Old Aug 5, 2005 | 06:27 PM
ws6formula98's Avatar
Default Zex Wet Kit Promble
I Installed My Nitrous Kit In My 98 Ws6 Formula, But When I Turned It On And Hit The Gas To The Flood, Nothing Happens. The Light On The Little Zex Box Turns On Green, But I Think Its The White Wire That Connect To The Tps. I Have It On The Gray Wire. What Color Does It Need To Be On?
Old Aug 6, 2005 | 01:10 AM
any one here with a zex wet kit for a ls1?
Old Aug 6, 2005 | 06:48 PM
RPM 6000's Avatar
Smile
Hi;
I got a 99 vette. My white wire goes to what looks dark green or black.There is also 4 other wires a bright green,two yellow,grayish purple.
Hope that helped.
Old Aug 6, 2005 | 09:25 PM
on my tps there onlys 3 wires . is the tps the one on the botton of the other sensor?
Old Aug 7, 2005 | 05:06 PM
BLACKBIRD8200's Avatar
I think it is the blue-ish wire on my car? mine a 2000 so it might be differant?
Old Aug 7, 2005 | 05:43 PM
1SICKhawk's Avatar
Should be a darkish blue color thats what it is on mine..but i have an 01 not sure if theres a difference or not.
Old Aug 7, 2005 | 06:15 PM
How Did You Know That It Was That Wire? Did You Call Zex Or Was It In The Intructions?
Old Aug 7, 2005 | 08:10 PM
red91z's Avatar
LS1TECH Sponsor
Put a volt meter on the wire. Hook the ground of the volt meter to a ground and the positive of the meter to the TPS wire you are connected to. Turn the key on and move the throttle. Closed throttle voltage should be around .67 and WOT voltage should be 4+ volts. If the voltage does not vary with throttle then you are not connected on the correct wire.
Old Aug 7, 2005 | 09:15 PM
What he said
Old Aug 7, 2005 | 09:36 PM
I Conected The Blue Wire And Programed The System. But When The Pedal Is To The Flood The Greed Ligth Starts To Flash Really Fast.does That Mean Its On, But I Dont Hear A Click Noise, Like It Saids On The Instuctions.
Old Aug 8, 2005 | 09:00 AM
NXRICKY's Avatar
Closed ex-Sponsor Account
Call ZEX they should be able to help you with the set up...
Ricky
