I need help.
Old Aug 9, 2005 | 04:57 PM
JEB99TA's Avatar
Default I need sound advice.
My new setup should be about 410-425 RWHP N/A (torque converter unlocked) at 11.1:1 compression ratio, will my LS6 intake hold solid for a dual 100/100 direct port setup? From reading the stickies and searching endlessly, this seems to be safe for a forged engine on 93 octane pump gas ... and a maybe good place to start. All the safety features will be included.
Maybe later I'll go bigger ... just want to be able to handle the new Z06's, new Cobra GT's, and the newer S/C'd Euro's. I know they're gonna' be picking on me because I own an F-body. Fun at the track is the most important, though. Will the LS6 intake be good enough?
Old Aug 10, 2005 | 08:38 AM
jimmyblue's Avatar
Moderator
Direct port bypasses the manifold pretty much, so
off the cuff I'd say there's no worries. As long as
no back-pop....
Old Aug 10, 2005 | 09:10 AM
Nitro Dave's Nitrous Outlet's Avatar
There is no worries as far as the plastic Intake.The problem is that there is not enough room to plumb a true directport on the intake like the truck intake we recently did for Nick. However you could plumb one stage a direct port and the other either a single nozzle or spray bars in the intake. Or you could plumb a single stage directport and use a controller like the maximizer.
Dave
Old Aug 10, 2005 | 12:13 PM
JEB99TA's Avatar
Now I'm thinking a dual nozzle 100 DRY setup with 150 pills setup on my MAF once my engine work is done ... later I could do the added 100 DP wet 100 shot as I had planned. Does this make sense?
Old Aug 10, 2005 | 01:04 PM
Robert56's Avatar
Now your talking. Or quad nozzle dual stage dry, don't tell Dave though.
Robert
Old Aug 10, 2005 | 07:23 PM
JEB99TA's Avatar
How would I do that? Window switch for both stages? Maybe a progressive controller for the first stage?
