? on how much i can spray
Old Aug 14, 2005 | 09:02 AM
shkettle's Avatar
Default ? on how much i can spray
i am new at nitrous-thats a given. i got a wet kit and planned on spraying w/ my new heads and cam combo. how much can i spray without getting
detonation if my compression ratio is 11.3-11.5. i dont want to use race gas and am still using the stock bottom end. i would like to use at least 100 shot
but was curious if i could get away with more.
-shaun
Old Aug 14, 2005 | 10:36 AM
Robert56's Avatar
100/150 no problem if tuned correctly. Fuel pump upgrade should be on the top of your list. Your comp ratio is not a problem at all, should log and check for KR though.
Robert
Old Aug 14, 2005 | 12:43 PM
Matt@HSW's Avatar
Like Robert said 150 shot no problem, as long as you have a good tune (pull some timing) and a fuel system that is adequate, you'll be good. If you need any help with either let us know.
Matt
Old Aug 14, 2005 | 03:54 PM
shkettle's Avatar
thanks guys. i got a fuel pump and that should be all i need. i have no where to buy race gas, so i wanted to avoid that road.
