Spray before or after the MAF?????????
Old Aug 21, 2005 | 03:21 PM
FartCanPolice's Avatar
Default Spray before or after the MAF?????????
I have a ZEX wet kit and have heard mixed reviews about where to put the nozzle. I want to spray AFTER the MAF but I still have the stock "accordion-like" bellows. My buddy sprays right in the side of his lid before the MAF and hasn't had any problems with the sensors, not sure about it but he also said when you spray in the lid the fuel-n20 mix atomizes a little better, basically what i'm saying is that will I hurt the MAF or IAT sensor if I spray before them?
Old Aug 21, 2005 | 03:23 PM
jamnut's Avatar
I would spray a wet shot after the MAF.
Old Aug 21, 2005 | 03:27 PM
Default ??
Does it matter that it will be so close to the TB. Many people (including vendors) say to keep it about 6" from the TB
Old Aug 21, 2005 | 03:32 PM
CAT3's Avatar
Restricted User
Go to Home Depot and replace the accordian with a 3" Fernco, yes it will be a tight fit over the TB but once there your good. Wet = post MAF, Dry = Pre MAF.
Old Aug 21, 2005 | 03:38 PM
Matt@HSW's Avatar
Definitely spray it after the MAF. The MAF was never meant to flow fuel through it. Look into picking up a smooth bellow. You could always run a fernco coupler as a smooth bellow.
Matt
Old Aug 21, 2005 | 03:41 PM
Default so then...
The nozzle should be OK then closer to the TB mounted into the fernco piece w/o any problems? (after all itll be tapped into a piece of rubber)
Old Aug 21, 2005 | 03:44 PM
Ouija's Avatar
IF the fernco is tight when trying to put it on, pop it in the microwave for 15-60 seconds and it will go on like butta.
As for mounting the nozle in the fernco, depending on yoru nozzle you probably could use a combination of washers and nuts to make a nice mounting that is secure on both sides of the fernco.
Old Aug 21, 2005 | 05:45 PM
sprayinss's Avatar
wet kit needs to be after maf,not b4,dry kit needs to be in front of maf,hope this helps
Old Aug 21, 2005 | 06:40 PM
mrr23's Avatar
here's pics of mine put into the stock accordian boots. the nytrex nozzle sprays out at a 45* angle. some spray out at 90*. i could be wrong. that's how my days been going so far.
Old Aug 22, 2005 | 06:42 AM
Airwolf's Avatar
How close is your nitrous line to the PS Pump pulley? From your oic it looks CLOSE! I am sure it's not, but in that shot it looks like it's resting on it. Also is your fuel line going to the fuel solenoid hooked up in that shot?
Just wondering...
Old Aug 22, 2005 | 09:53 AM
SiL3NtXWS6's Avatar
This is where i put my nozzle as well.
Old Aug 22, 2005 | 04:18 PM
mrr23's Avatar
Just wondering...
when i took that pic, the lines weren't connected to the solenoids.no, the fuel line wasn't connected when i took the pic.
Old Aug 22, 2005 | 06:06 PM
Airwolf's Avatar
That explains it; actually I kind of figured.
Update those photos!!!
