need help wireing
Old Sep 1, 2005 | 08:15 PM
00formLs1's Avatar
Default need help wireing
i have a custom wet kit and i can't get my solinoids to click open with the wot switch. i have the jimmy jams activation and wot switch. i have a msd digital window switch but i didn't have it hooked up. i used a diagram i got on this site and no luck. could it be the window switch not being connected and it does not complet the circuit?, also what 12v source did you guys tap into?
Thanks
Eric.
Old Sep 1, 2005 | 10:03 PM
brad8266's Avatar
I used the positive post by the fuseblock on the drivers side under the hood, for the ignition switched 12V I used the fuse panel near the drivers door. There is ignition switched power off I believe the leftmost second fron bottom contact. Go to nitrous express site, they have great wiring diagrams there, i used them and mine worked fine on the first wiring.
Old Sep 3, 2005 | 10:29 AM
00formLs1's Avatar
i'll try that, thanks
