can i spray a 100 shot on a tci4000?
was thinking about adding a small 100 shot to my setup but don't really want to change the converter..anybody eles sprayed a big stall 4000 plus... on there setup..how did it work out...never ran nitrous before so i;m just doing some research before i buy.... thanks..
I am about to put in a NX Wet kit on my 01 Vette (A4) and I am in the same boat as you.
I have an SS4000 with a 2.60 STR so it is a tighter 4,000 stall if that makes any sense. My shift extentions are at 5,200 and my PCM i sprogrammed to shift at 6,500. I also will be installing a BMN Window switch so I will program it to spray like ON at 4,000 and off at 6,400.
I talked to Patrick G. a Big TC Guru on this Board and he sprayed with his 4,000 stall and kicked some butt, so although it is not the IDEAL TC, you will be fine.
Good Luck
Gary
Good Luck
Gary
