Questions about tnt power ring..
Old Sep 7, 2005 | 08:40 PM
2001 Red Coupe Bandit's Avatar
I have the steel TNT Ring (possibly the older version). I am putting mine on a 2001 Vette that has a smooth air coupler.
Mine doesn't have any type of rubber seal/ring. Do I need one? Maybe it is easier on a Vette.
Old Sep 7, 2005 | 09:00 PM
Black02SS's Avatar
Originally Posted by necrocannibal
Well the lid is a pain to get to fit but the screw at the top IS NOT a set screw. Its a screw to mount the solenoids. You guys just sound like you have ingenuity and tried for a couple of minutes to put it on and said screw it. Mine actually went on and sealed in all of 30 seconds.
LOL The screw at the top IS a set screw. The newer design changed the placement of the solenoids with a new bracket that uses the side bolts on the throttle cable bracket to attach it. I have tried many different options and none worked for me. I have had the kit for some time now and have installed several so this wasn't my first attempt.
Old Sep 7, 2005 | 10:03 PM
LoWeLL216's Avatar
Funny, I was thinking how the hell would that screw be for the solenoids...
Old Sep 7, 2005 | 10:04 PM
MakoLS1's Avatar
Beat the power ring on with a rubber hammer, and then cut about an inch or so off of the air bellow. Its easier to cut the airbellow then the air lid!!!!!!!!
Old Sep 8, 2005 | 07:51 AM
necrocannibal's Avatar
The one I have has a screw at the top and its for the solenoids as it isnt even anywhere near where the TB is on the ring and it fit perfectly fine. I dont know about any newer one that you guys might have. You have a link to a pic or something?
**EDIT**
This is what mine looks like.
This is it installed
Old Sep 8, 2005 | 07:58 AM
Black02SS's Avatar
Give me a sec and I'll have some uploaded for you.
Old Sep 8, 2005 | 08:09 AM
Black02SS's Avatar
Here is a pic that shows the set screw on the inside and outside of the ring. Its obvoius that we can't attach our solenoids to this. I believe they went to this design about a year or so ago. I purchased my TNT kit back in the summer of 03 I think.
Old Sep 8, 2005 | 08:33 AM
Yeah thats looks totally different from the way mine looks. If you look at the pics in my post and look at the screw on mine it obviously is a solenoid screw.
Old Sep 8, 2005 | 09:06 AM
JRracing's Avatar
I have the newer version also and it was hard getting the ring pressed on. Very tight fit. But you want it to seal good.
