BMN, Shift Light, Rev Limiter Settings
Old Sep 7, 2005 | 01:11 AM
LoWeLL216's Avatar
Default BMN, Shift Light, Rev Limiter Settings
Just wondering where everyone has their shift settings at. I'm thinking about setting the BMN around 3000-5500. Since I'm using a shift light is there any reason not to set it to 5500 also? Where do you put the rev limiter? 6500? Just trying to err on the side of safety. Thanks!
Old Sep 7, 2005 | 05:12 AM
XTrooper's Avatar
Set your upper rpm limit 200-300 rpm below your shift point. I'd set my rev limiter around the same amount above my shift point.
