How hard is it....
Anyways, any info is very appreciated.
P.S. - Nitrous will only be used at the track. Should cut down on whatever wear I might see. I will only be makin it to the track maybe 2 times a month.
As far as NX, they only do wet kits, not dry. If I was only spraying a 75 shot I would stay dry. Dry is easier to install, works fine and the A/F ratio should be fine as it is controlled by the ECU.
Anything larger then the 75 shot and more options/set-ups would apply.
Now the wear and tear. Does not come directly from the nitrous, as long as the nitrous that is install is at or below the level the engine can handle...
The ls1 engines are extremely tough little cookies so a 75 no problem.. The real wear and tear comes from your foot going to full throttle more time because it is just more fun..
Run good oil, 2 steps colder plugs, good gas, and let it rip. You will be
.Ricky
NX does not offer any dry kits.However a DRy kits are built for us by NX.So we may have had a small miscommunication.With our dry kits you still get the NX quality
Dave
