Fuel Pressure Riser
Old Sep 8, 2005 | 02:08 AM
GDM Z28's Avatar
Default Fuel Pressure Riser
Do i need this for a 00 WS6 with stock fuel system on a 100 shot dry or will the maf add the extra fuel?
Old Sep 8, 2005 | 04:51 AM
DD966's Avatar
The MAF does all the work (very simplified explanation). You don't need a riser.
Old Sep 8, 2005 | 05:16 AM
XTrooper's Avatar
Your stock fuel pump should be able to handle a 100 shot, but those '00 fuel injectors may not be up to the task. I'd swap them out for at least a set of 28.8# OEM injectors.
