Wiring help
Old Sep 10, 2005 | 11:14 PM
BlownChevySS's Avatar
Default Wiring help
I was wondering if there was a way to hook up the nx without the relay? 40 bucks for a relay is crazy!!!
Old Sep 10, 2005 | 11:26 PM
white2001s10's Avatar
Always use a relay. Radio shack or walmart usually sells them for $5 or $10.
Old Sep 11, 2005 | 01:56 PM
Matt@HSW's Avatar
Radio Shack relay will work. Or if you want one with a wire harness we have a 40 amp one for $18.95.
http://www.harrisspeedworks.com/shop...cat=312&page=1
Matt
Old Sep 14, 2005 | 05:58 PM
I was told I need a 60 or higher amp relay. So a 40 or 30 will work?
Old Sep 14, 2005 | 08:31 PM
Matt@HSW's Avatar
60 amp? What are you trying to hook up?
Matt
Old Sep 16, 2005 | 03:47 PM
I printed out the install manual from nx and in them it has a 60 amp relay as part of the gear. The only thing getting hooked up are the fuel, nos, and purge solenoids.
Old Sep 16, 2005 | 04:25 PM
SSDriver's Avatar
You wont need anthing larger than 30-40 amp. I was running a 40 amp relay with a 30 amp fuse on my DP kit that has 2 nitrous, 2 fuel, and 1 pruge solinoid with no problems at all.
-William
