Please help guys! In the middle!
Old Sep 14, 2005 | 05:37 PM
Smoker_98's Avatar
Default Please help guys! In the middle!
Ok Im still trying to get the 5177 to fire without any luck. I really think its either the wot switch or the fpss. Ok how can I bypass the fpss? Do I just "jump" the two onto one of the screws? If so then could I set my window switch down to idle and then click the wot switch? Obviously the lines will not be spraying into the air box.
Old Sep 14, 2005 | 05:40 PM
XTrooper's Avatar
Yes, all you have to do is connect the two wires going to your FPSS together with the WOT switch on and it should fire. Be careful where you spray that nitrous and fuel!
Old Sep 14, 2005 | 05:42 PM
XTrooper's Avatar
If it is the FPSS, try adjusting it a 1/4 to 1/2 turn (counterclockwise) as it may be set a little too high. I just had to do the same with mine.
Old Sep 14, 2005 | 05:47 PM
Smoker_98's Avatar
I tried that and its not firing! I undid the lines from T so that n20 would spray out, but not into the lid. . ... Any suggestions? Could wot switches go bad? It used to work 6 monthes ago I just never filled the bottle back up again. Ive checked and re-checked all my wiring.
Old Sep 14, 2005 | 06:06 PM
Smoker_98's Avatar
See the thing is my purge still works fine . ... So I know my wiring has to be right. Its was all done the same. So why wont the main noids fire?
Old Sep 14, 2005 | 07:09 PM
dlmater's Avatar
If you have eliminated the FPSS by jumping it, the window switch and WOT switch would be the next thing to check. Any switch can go bad, including the solenoid itself. Do you have an electrical meter to check continuity across the WOT switch contacts? You can buy really inexpensive ones at any home store, walmart, auto parts stores, etc. This would be the best way to check all the wiring such as switches, relays, etc. without removing components or guessing. Good Luck
Old Sep 14, 2005 | 07:40 PM
XTrooper's Avatar
As already stated, any switch can go bad, so it could very well be a bad WOT switch. You could check it even with a simple hot wire tester (the ones that are built like an ice pick with a bulb in the handle and an alligator clamp on the end of a wire for grounding. Just arm the system, hold the WOT switch closed, and check to see if you're getting power in the wire from it to your solenoid. If you're using a window switch, it would be my prime suspect, but you could still eliminate the WOT switch as the problem by checking it as described. It's highly unlikely, though not impossible, that it's the solenoid(s) itself.
Old Sep 14, 2005 | 10:24 PM
Nitro Dave's Nitrous Outlet's Avatar
Smoker,
Take and unwire the solenoids.Make sure that one wire from the solenoid is grounded good.Then take and run a temporarily run a hot wire from your battery to the other solenoid wire.Make a connesction and see if the system fires.Make sure the car is not running and the nozzle is not blowing into the engine.If the system fires you have a bad relay or wiring problem.
Let me know if you have any further questions.
Dave
Old Sep 14, 2005 | 10:25 PM
What brand window switch and desigh are you using?
Dave
Old Sep 15, 2005 | 09:45 AM
Smoker_98's Avatar
Its a digital MSD, I think it may be the solenoid(s) I guess I need to test them and eliminate the failing one. Thanks for all the help guys!
Old Sep 15, 2005 | 11:12 AM
NitrousDirect's Avatar
Did you try direct battery popping the solenoid?
Old Sep 15, 2005 | 12:40 PM
Smoker_98's Avatar
Im not familiar with that method, care to explain? Thanks!
Old Sep 15, 2005 | 01:03 PM
Meaning just touch the wires from the solenoid directly to a battery solenoid to make sure it opens and closes on it's own. Have you tried that?
Old Sep 16, 2005 | 06:10 AM
Smoker_98's Avatar
No but I will over the weekend, I'll report back. Thanks!
