can nitrous leak cause high idle?
Old 09-17-2005, 12:03 AM
Paulz2820's Avatar
Default can nitrous leak cause high idle?
well i just put my kit on and the pipe fitting to the in side the solenoid is leaking i tried to fix it but its still leaking. i went ahead and tried it out, afterwards my car was idling at like 1000 which is unusual because normally it will barely even idle. No a/c on this either. could the nitrous leaking under the hood cause the car to idle high if it was leaking enough? it seems feasible and the MAF would pick it up like a dry shot while i'm sitting on a light thats not good though.
Old 09-17-2005, 12:34 AM
Robert56's Avatar
If it's the n2o, it would be leaking past the noid to cause this problem. Try shuting your bottle off and bleed line and see if idle comes down.
Robert
