Spray through shifts
I just use an MSD window switch with an upper rpm module that is 100rpm lower than my shift point.
Jim
has anyone seen a gain from spraying b/w the shifts versus stoping the spray like me at 200 rpms before the shift?
Lets see how long it last running in the 10's
It has also been stated that you don't gain anything spraying through the shifts but I see it as a delay, nitrous has to turn off then back on while the trans shifts pretty dang quick. Do you guys that use a window switch and shut it down even notice it?
