Clever ways to hide nitrous
Old Sep 23, 2005 | 10:42 AM
Z284U2TRY's Avatar
Go dry way easy to hide and no one will know.
Old Sep 23, 2005 | 10:44 AM
BAKED's Avatar
Just do like Darrell Alderman and hide it in your oilpan.
Old Sep 23, 2005 | 10:51 AM
Ouija's Avatar
My nitrous system isn't technically hidden, but most casual looker totally overlook it.
I have my noids installed on a bracket where the EGR used to be and peeled the stickers off them.
I've wire loomed all the nitrous lines, and electrical connections. The relays are placed on the driver fender well.
My dead giveaways are the two nozzles going into the MAF bracket, the red/blue end connections on the lines, the purge tube, FPSS, and the nitro controller.
The FPSS will be hidden once I finish my fuel rail covers.
If I wanted to finish hiding the system, I would just hit the red/blue line ends with a little sand paper. Paint over the writing on the nitrous controller, reroute my purge tube, and then figure out a new maf end, or switch to a TB plate.
People see the noids where the EGR used to be and never question it.
Old Sep 23, 2005 | 11:37 AM
Black8Banger's Avatar
its a shame someone doesnt make a nozzle that looks like a sensor. That way you could run the lines together with the throttle body sensors, air sensors and what not. It would appear to just be another sensor in the MAF or throttle body! Talk about hidden!!......
Old Sep 23, 2005 | 05:41 PM
PERFECT Z28's Avatar
I just covered my nitrious lines and electrical wires with loom and I made a little box to cover the solenoids and to protect the 'noids from the radiator's HEAT. It looks really stealth and only the guys that are looking for it can really tell I have it.
Old Sep 23, 2005 | 06:04 PM
NitrousDirect's Avatar
You could always go the route of our direct efi nozzle setup where the nozzle goes into the injector port and the injector then fits into the nozzle.. a little less noticeable then something ported into your intake
you can see it here
http://www.nitrousdirect.com/wetnitrouskits.html
about 30% down the page under the title
Direct Port E.F.I. Nitrous Kit for Fuel Injected LS1/LT1 and GM Trucks
Old Sep 24, 2005 | 06:47 PM
4thGenTA's Avatar
i'm in the same situation with my DAD so what i did was buy a NOS wet kit and put the solenoids under the black plastic in fornt of the air lid and ran hard lines (brake line) up through a hole i cut in the bottom of air lid and bent them and ran them all the way through the the intake behind the MAF sensor. THen i just put a T fiiting in my fuel line under the car so there was no line comming off the fuel rail. the only way you could see anything was if you layed on your back and looked up under the front end in front of the radiator. Also made an ash tray switch panel with quick connects so i could disconnect the switch before my dad drove it.
Old Sep 24, 2005 | 08:01 PM
TwoFast4Lv's Avatar
Mine was completely in the Loom and shot in the MAF back side. Ran main bottle in Spare and 5# backup under sub
