Fuel Pump
Thanks
http://www.harrisspeedworks.com/shop/home.php?cat=330
Matt
Matt
EDIT: If you go with ANY EFI DIRECT PORT KIT on a LT1 you will have to do something to your rails, weather you cut the cross over or you bend it up. Just wanted you to know that this is not a Cold Fusion thing, but an issue with the LT1 fuel rail system that you'll run into with any manufactures "EFI" direct port.
Thanks
It's such a minor thing on the lt1 the injector sits a tad higher after the nozzle is installed so if you want a quick fix you can just shorten the cross line or bend it a tad, issue solved, it's really not that difficult i have done several myself and it applies to any system and brand as far as I know, just part of the install process. It's just a case of someone trying to stick their .01 in and be seen, guess anyone can post on the internet these days lol!
Don't be disuaded from any brands direct port nozzles on an lt1 it's a REALLY sweet setup anyway you go.
