New TNT sticker?
Dave
pull his jets and put them in your car or put yours in his. You will see it isn't a difference in the systems just the jetting.
Dave
I disagree.. From some of the earlier threads I wouldent claim your numbers to be "dead on" there Dave.. Also think about it, you claim to have this "High flow" sol, and a "High flow" 45deg bottle valve and use "High flow" Y fittings instead of our "restrictive" T fittings with your jetting set @1050psi.. Yet you argue that we use way more nitrous @900psi with a 90deg bottle valve and use "restrictive" T fittings.. So all of this power comes from an .002 jet size difference on the nitrous?? Am I hearing this correctly??
I just want to say one thing.
Your 150 shot jetting for a F1 is 46 Nitrous 25 fuel.. NXs jetting for there dual nozzle kits is 41 Nitrous 22 fuel.
Enough said..
Not worth my time.
Dave
I personally dont pay much attn to manufacturers ratings as long as I am close. I like to slap it on the dyno...make sure i am close...then make changes get the ACTUAL HP and Af right where I want it. I then label each set of jets and put them in my little tackle box that is marked on the outside.
The engine doesnt really care or know if the nitrous kit manufacturer is making any extra hp from XX jets. It just uses what inputted to the engine to output power at the wheels.
I used to use the most OVER RATED kit on the market in the NOS 5177 kit. Everyone seems to make about 70 hp on thier "100 shot". Does that mean I was loosing power but the engine was taking the abuse of a 100 shot??? Of course not. I just increased the jet sizes until I reached the desired HP level and then marked those jets for what they really where. And I sprayed dual stages through that slightly modded NOS 5177 kit all the way up to a 300 shot (actual RWHP).
All of these kits will make all the power you will EVER need with minimal changes! Every single last one of them! So IMO basing your purchase on whos labeled 100 shot makes the most power is not the best way to do it. After all..if you are making a 125 hp at the tires on a specific shot...your spraying a 125 shot plain and simple as far as the motor is concerned.
I personally feel the purchase should be based on quality, customer service after purchase, upgradability, value...in that order.
We have many good kits out there to choose from.
Good points made here! Now put the powerglide in the car, jet up the nitrous and put that car WELL into the 8's already!
if i jet for 100hp i want to see 100hp. i like the NX jetting. why call it a 100 shot when its actually a 125-150? personally i'd be pissed off if i paid the $$ for a TNT kit and the jets arent even close to being accurate.
