timing
Old Oct 20, 2005 | 08:10 PM
GDM Z28's Avatar
Default timing
are any of you guys using a digital 6 to pull timing when the nitrous is engaged? I was thinking of running a digital 6 for timing and a msd digital window switch so i dont spray through the gear shift.....is there any thing else i can use besides those two things? TIA
sparky t/a's Avatar
how much are you gonna spray trent? if its 100 or less dont worry about it.
Old Oct 20, 2005 | 08:11 PM
GDM Z28's Avatar
i wana hit it with a 150
Old Oct 20, 2005 | 09:02 PM
Robert56's Avatar
If your stock and stock timing, 150 hit is still no worry. I would still log and check for KR if it were mine.
Robert
Old Oct 20, 2005 | 10:09 PM
GDM Z28's Avatar
Robert
im gonna put the timing to stock or try to get something to control my timing while im on the bottle (maybe a digital 6) but right now the car isnt stock. it has heads and cam, ls6 intake, ported TB, pacesetter LT's, etc.
Old Oct 21, 2005 | 12:25 PM
Matt@HSW's Avatar
LS1 Timing Tuner sounds like it would fit the bill. It'll allow you to run full timing off the juice and pull it when you spray. It also has a window switch. Here's a link for more info:
http://www.harrisspeedworks.com/shop...age=1&featured
Matt
