MSD Digital Wondow Switch Display Question?
Old Oct 21, 2005 | 01:53 AM
2001 Red Coupe Bandit's Avatar
Default MSD Digital Wondow Switch Display Question?
Looking at my MSD Digital (in my glove box) while I was driving and I see the on and off RPM's etc. and I knwo you hit MODE and put it on 4 CYL for our Cars.
BUT
The whole time the window switch keeps showing 1.4, 1.3, 1.5 , 1.4 it just keep schangign and scrolling on the read out.
What is this? Is thsi just showing the Voltage Reading??????????
Thanks
Old Oct 21, 2005 | 05:45 AM
XTrooper's Avatar
It "should" be reading your engine speed. Were you just cruising in OD? The 1.4, 1.3, 1.5 would represent 1400, 1300, and 1500 rpm.
Old Oct 21, 2005 | 08:16 AM
PERFECT Z28's Avatar
I just installed my MSD digital W.S. I need to know if I hooked up the power correctly The way I have it set up now, it is drawing its power from the microswitch by the throttle body. It only turns on when my toggle switch is armed...is this correct? It reads the engine's RPM when the toggle switch is armed. I haven't had a chance to test it out, I broke my tranny's tailshaft and bent the output shaft 2 weeks ago (2nd time) and I should be rebuilding it on monday. I just want to know if I installed the W.S. correctly so that I can make sure it will work.
Thanks for any help.
Old Oct 21, 2005 | 08:34 AM
XTrooper's Avatar
As long as it's a switched power you're using (which you are), it should be fine like you have it.
Old Oct 21, 2005 | 10:03 AM
Thanks Xtrooper
Old Oct 21, 2005 | 10:29 AM
Mine is on all the time. I was sitting there at idle! so that is all it was reading.
Thanks Trooper
Old Oct 21, 2005 | 11:16 AM
Hocky's Avatar
Thanks Trooper
That was engine speed. Either your car idles pretty high or it was not actually set on 4cyl mode.
