NX Max 2 question
Old Oct 27, 2005 | 03:06 PM
Airwolf's Avatar
Default NX Max 2 question
Does the Max 2 work in a set time frame, meaning once activated, it runs the program set for it, and does not reset? I am wondering this because I do not want it to "reset" when I lift my gas pedal to shift. (Unlike most, I actually do slightly lift on my shift!). Will the Max 2 work for this, and if yes, how long is this time before a reset/restart of the program?
Thanks!!!
Old Oct 27, 2005 | 03:56 PM
Somebody09's Avatar
YOU tell the Maximizer how long you want to wait before it resets. Mine's set for 30 seconds.
Old Oct 27, 2005 | 04:04 PM
NXRICKY's Avatar
Closed ex-Sponsor Account
Ok there are serveral options here... depends on how good of a driver you are.. How fast you shift...
1st, set your trigger point at like 75% throttle and do not lift enough to less than 75% throttle, the box will not reset. OR stop spraying during the shift... I do not recomend this one. BECAUSE you miss a gear BOOOOOOMMM>
2nd Set the Maximizer 2 gears up, and set each ramp where you lift to kick up where you left off... Meaning you shift at 6000 and 40% 2nd gear needs to start at 40% and so on and so on..
option 3, set at RPM mode and let rip.
Ricky
Old Oct 27, 2005 | 04:07 PM
NXRICKY's Avatar
That is dealing with a street application, meaning if the maximzer is armed and not in use it would wait that amount time to reset the gear selection..
Ricky
Old Oct 27, 2005 | 04:09 PM
Somebody09's Avatar
eh... That's the only option I use.
Old Oct 28, 2005 | 08:18 AM
Airwolf's Avatar
Thanks for the input. This unit sounds better everytime I inquire about it.
Old Oct 28, 2005 | 09:26 AM
02 Pewter LS1's Avatar
I agree it sounds like a winner.
Hurry up and get one Mike so we can check it out.
Old Oct 28, 2005 | 09:29 AM
NXRICKY's Avatar
yea, hurry up and get one.
Ricky
Old Oct 28, 2005 | 10:17 AM
Phil99vette's Avatar
7 Second Club
Mine just got here, going to pick it up in a couple of minutes. The fun part is rewiring the whole system.
Phil
Old Oct 28, 2005 | 10:25 AM
Phil
That is the part that I don't look forward to. I have all my connections made inside the car just under the dash on the passenger compartment. Everything is soldered,shrink wraped,wire loomed and wire tied so it looks like factory.
Let us know how you like it and post up some pictures when your done.
