Nitrous Outlet LS1 Intake System..
When someone gets this on their car ( preferrably a h/c 346 ) please post up the n/a dyno results, preferrably over a ls6 w/ ported tb. Thanks.
Do you know if this will work in a C5 with say a Nick Williams TB? Have you tried fitting one in a 'Vette yet? I'm not concerned about hood clearance as I have a high-domed hood.
Looks nice, but where do the nitrous and fuel lines run into the intake?
And one more for now, why use the rubber feed from the hardline to the AN fittings, why not use a Russel hardline to AN fitting?
I agree with your thought about just going straight from Hardline to AN, I think that would actually look and function better.
Those New NX solenoids Look SWEET!!!!
What if I already have fuel rails, and mounts that came with them?
Can I use your mounts for the fuel rails, and use my fuel rails? Or are your fuel rails drilled in a different location, than those rails offered by other companies (Nate, Speed Inc, etc)?
Do you weld bungs to the intake for the fuel rail mounts, or how are those setup?
What nitrous solenoids are with the kit?
Can it be bought without the bung for the evap?
Just trying to get a bunch of answers for those of us that have been waiting for this.
2.If you already have fuel rails you can keep them and subtract a 100.00. They may not fit with out the brackets and spacers that come with ours. If the customer does not order this unit with the fuel rails they will have to make theres fit.
3.The intake already has a place to bolt down the fuel rail brackets.
4. This set up that is for sale is just the intake set up with spray bars plumbed in. The nitrous system will be a additional purchase.
I guess you are reffering to the fittings and braided hose that we are ubsing for the fuel feed from the stock line. We found this just to be more universal so that the customer does not have any fitment issues.If the customer would rather have hard line we can set them up with the needed parts to do so.
Thanks
Dave
But I am a little bias. lol
Ricky
This isn't really meant for a daily driven street car. With such short runners it will definitely move the power band up meaning less tq more top end screamer.
If you are running big cubes (400+) or really high rpm (7500+) or solid roller setup this would work awesome. Otherwise the gains N/A wouldn't really be worth it on a street driven 346.
It is a nice unit though for its intended usage.
Nate
NATE said it best right here.
This intake is not for the average Joe. This is for the guys making serious HP with a higher Reving motor. The NA/ and Nitrous gains will be determained by the combonation of the motor it is sitting on.
If you call Edelbrock they do not have flow numbers on there intakes. So I do not have flow numbers on this intake. However Common sense tells me that this is a higher flowing intake and will be perfect for Mid to high range RPMs.
We will see this weekend how this intake performs on a stock cubed LS1 with a TREX cam and home ported set of LS6 heads with stock valves.WE will be on the dyno hopefully saturday.
Dave
This set up is the intake with spray bars,fuel rails,brackets,spacers,hoses,fittings,elbow,and throttle body. The nitrous system will be a addintional purchase.
Thanks
Dave
Dave
I am very interested in seeing how it performes on a 346 cube motor. It would be nice to see it also tested on a larger motor like a 408 or bigger.
Again, very nice product Dave.
As far as the hardline to an fitting, I ment to word it where there would be a braided line thrown in the mix. Example... http://tinypic.com/el4fmg.jpg
Dave
