Nitrous Plate prototype
Old Nov 8, 2005 | 05:28 PM
Pewter_LS1's Avatar
Default Nitrous Plate prototype
Here is a few photos on a LS1 based Nitrous Plate my buddy Dale is workin on. This is a protoype for test fitting and everything else to ensure proper fit etc. Thought I'd share our idea with you guys and get some feed back. The plate has been on my car since 3 Nov with no visible complications, leaks etc. This weekend we will finish the install and get a few sprays in...and I'll keep you updated!!
Stock LS1 Throttle body and intake..
Removed Throttle body and air box..
Nitrous Plate..
same plate Different back ground...
Side shot with fogger..
Plate up to the intake..
Side shot mounted...
another...
top...
Inside shot with blade open..
another...
Old Nov 8, 2005 | 08:00 PM
00SS4780's Avatar
Looks great man!
Old Nov 8, 2005 | 08:42 PM
JoeyGC5's Avatar
Hows it holding up to te engine heat? Any warping?
Old Nov 9, 2005 | 01:10 AM
Robert56's Avatar
The problem may be the front cylinders missing out. May be spraying right past them. take a look at the new generation of plates, ie: Nitro Dave, NOS, as they have addressed this issue, and should give some insight.
Robert
Old Nov 9, 2005 | 10:40 AM
David@TNT's Avatar
Robert
Well put, and the downside to plastic is that eventually you will have material defects.. Good idea though, I allways respect people that are willing to come up with new ideas.. David@TNT
Old Nov 9, 2005 | 10:52 AM
NXRICKY's Avatar
Closed ex-Sponsor Account
Interesting and that nozzle damm looks good... ? for U. The plasic spacer is it, lexan that was cut or molded? I noticed that the side are really clean and clear, like molding, and your drilled holes are cloudy,from drilling and or machining..
Ricky
Old Nov 9, 2005 | 11:07 AM
Nitro Dave's Nitrous Outlet's Avatar
Nice work.... Its interesting to see new thing. However that is placing a nozzle two close to the two front runners. I have seen distribution problems from doing it this way. Be careful.
Dave
Old Nov 9, 2005 | 12:02 PM
Pewter_LS1's Avatar
I hand cut it out of a pace of lexan. It gives me a good place to put the nozzle, how about two nozzles one high and one low or a spray bar going from side to side?
Old Nov 9, 2005 | 12:11 PM
Thats a nice cut job on the lexan. Its not really a fact of one or two nozzles.Its the fact that a nozzle is desighned to spray two heavy beams of nitrous and fuel outwards.The nozzle directs the spray patter towards the back of the intake. The two front runners are so close that it creates a distribution problem.I have learned this from helping many customers trying to problem solve zapping plugs and pistons on different HP levels. There are a few comapanys on the market that use a similair desigh to what you have done for the LT1 and LS1. It seems that the guys spraying the smaller shots do not see the problem as much until they step up on the size shot.
However you have done a good job. Just letting you know about the potential distribution problems.
Dave
Old Nov 9, 2005 | 01:06 PM
Pewter_LS1's Avatar
Thanks Dave for the info..
Old Nov 9, 2005 | 03:51 PM
BigSteele's Avatar
looks awesome. good job on it
Old Nov 9, 2005 | 05:47 PM
99FormulaWs6's Avatar
What's a smaller shot? 100? 125?
Old Nov 9, 2005 | 08:15 PM
Robert56's Avatar
Something you may try to minimize any potential problems, is try pointing your nozzle down a bit, instead of 90*. this may help the front clyinders out instead of totally bypassing them. If you look at the new ones, this seems to be the answer as far as I can tell. they spray down from the top and is then pulled into the plenum?
robert
Old Nov 9, 2005 | 09:32 PM
Somebody09's Avatar
Off Topic: Dude I love the car in your sig. I'm assuming it's yours Your rear window tint is the badest thing i've ever seen, and where did you get those rims? I tried looking for them but I can't find any powder coated ones.
-somebody
Old Nov 10, 2005 | 09:34 PM
Pewter_LS1's Avatar
-somebody
thanks man and yea its my car...
the rims are Smoothie II's Boyd Coddingtons Gun Metal Grey 17X10..
