MSD Digital bad maybe
. After more testing I found that they both will open if I ground the soleniods wire at the noid basically bypassing the msd. But for some reason the nitrous noid opens but the fuel will not using the msd. The fuel noid was making alittle vibrating noise which would tell me it trying to open but maybe isn't getting a good ground. I just came in from regrounding the msd and no luck. Any ideas, all the wiring is from a 05177 maybe it's not big enough.
again. Trending Topics
Here is what I have. The wot switch is grounding the relay, the msd is grounding the noids. So should I use the wot switch to ground the noids and the msd to ground the relay.
4th page on these instructions is the way it should be wired. Yellow is the same on the msd as it is on the nx window switch.
Robert
Robert
IT WORKS, all is well.
Thanks guys.
