Building the SAFEST Wet Kit Possible
Old Nov 28, 2005 | 09:32 AM
NXJeremy's Avatar
Originally Posted by WAHUSKER
If you are using a FAST intake, add some burst valves to your list....
The burst panels are highly overrated in my opinion. Out of the several FAST intakes that I have seen after explosions, not a single one of them had the burst panels rupture. That's not to say they don't work, I'm sure they do in certain situations. Just my opinion that they are overrated.
Old Nov 28, 2005 | 10:38 AM
JoeyAnderson's Avatar
I will be using an LS6 intake for the time being. The FAST will come with bigger cubes one day (eventually...)
Old Nov 28, 2005 | 10:40 AM
NitrousDirect's Avatar
Jeremey weren't you working on some sort of improved system?
Old Jan 18, 2006 | 06:22 PM
In case you all are wondering, the word "[check]" next to some of the items in my list are there because as I purchase the parts, I want to remember what I've got and what I need to order.
Old Jan 18, 2006 | 10:23 PM
The Sad's Avatar
I am looking run N2O as safe as possible too. Your list sounds a lot like mine. However, (and correct me someone if I am wrong) it doesn't seem like you need the fuel pressure switch and the air fuel switch. I was planning to run the air fuel switch only because it would shut me down for running lean if I didn't have the fuel pressure.
And about redundant noids, I plan on using a noid style opener. Remote opener and way to quickly shut off the juice if regular noid sticks. 2 for 1 (someone can correct me if I am wrong here too)
Old Jan 18, 2006 | 11:00 PM
Dragframe's Avatar
do direct port and you will pretty much get rid of the leaning out problem...
Old Jan 18, 2006 | 11:33 PM
Robert56's Avatar
Yep 2 for 1, except I did 3 for 1, meaning redundant 5177 noids and a constant voltage type noid opener on my '97. Three noids of defense.
Robert
