Spraying off the line A4
minimum.( DISCLAIMER***** depending on shot size)
but are you sure of this?
Hawk
BTW -I agree if you do spray from home use a Dry kit(IMO)
you're toast. And i suggest a 'Dry' set up i'm just guessing you're new to
spray.
Hawk
I bet that turns into a Yank 4,500 if I spray out of the hole?? i will have to check when I try it one day, still haven't sprayed at the track yet.
Granted, it took my rear end out.. Well, not really. It just whined like a mofuka.
I say jet correctly, and then go for it. If it does backfire, hell, a new intake manafold might be in order.
^ the above post is my opinion only. These opinions are not to be taken to the grave. Do what you want to do, i did.
By spraying out of the hole, i acheived a 1.7 60 ft, on Nitto DDR's on a subframe connected Dragshock stock convertor car. HTH
thing is, a nitrous stall isnt that much more than a non balloon plate stall, so why even chance it. they make them for a reason, follow the pro's!!!!!!
But for peace of mind your right, just be safe. Later
