Logged: Lean A/F: Small Dry shot
Old Dec 11, 2005 | 03:25 PM
Sport Side's Avatar
Default Logged: Lean A/F: Small Dry shot
Here is my simplified question. I know some get tired of reading all of the inbetween stuff and would rather just see the question:
Why would my 5.3L w/ bolt ons be running 13.3-13.9 A/F ratio on a .44jetted(75 shot roughly), single dry shot?
I just installed a small dry shot on my internally stock 5.3L. The only mods done to the motor are a CAI, Ported TB, and exhaust work.
Just a bit earlier I went and ran a log to see where my timing and A/F ratio were reading at.
1. My STFTs range from -2 to +2 for the most part.
2. Advance NA is 30*
3. I went WOT and NA the A/F was 12.5-12.9
4. NA, advance g/cyl is between .60 and .72
5. Nozzle is 7'' away from MAF
After seeing my NA tune was doing well, I flipped open the n2o act. switch and purged the air out of the line. Increased speed to 40mph, (aka suck-*** gear for a stock 60e) and went WOT.
1. Timing remained in the NA g/cyl cells.
2. Still 30* of max timing
3. A/F ratio ranged from 13.3-13.8 (slightly increasing as rpm increased)
It seems to me that the MAF is not recognizing the Nitrous charge.
Why wouldn't I enter under more load?
Please help,
Thank you.
Old Dec 11, 2005 | 11:03 PM
Robert56's Avatar
One thing i forgot to mention on the other forum was your nozzle placement. can you give a quick run down, maybe the shot is basicaly getting past the MAF wire and causing a lean condition?
Robert
Old Dec 12, 2005 | 05:05 AM
Sport Side's Avatar
Robert
The nozzle is placed 7'' before the MAFs fitment in the air stream.
I'm not sure how well nitrous is distributed when injected....
I wrote a lengthy response.
Thanks again.
Old Dec 12, 2005 | 07:04 AM
cantdrv65's Avatar
Post
Maybe the MAF sensor is bad....it SHOULD be seeing the change in temp in the air, thus increasing the air flow signal to the PCM. Id try another MAF if you have one available. How you removed the screen? If not that could POSSIBLY help some.
Or you could just go to a wet shot.
Old Dec 12, 2005 | 09:31 AM
98redorangeta's Avatar
I thought dry shots tend to be a little lean with out tunning any way my buddy almost found out the hard way with his mustang he sprayed a dry shot and was 16 to 1 before he got it tuned.
Old Dec 12, 2005 | 02:57 PM
Sport Side's Avatar
Thanks for the help.
I think it's the MAF sensor.
Old Dec 12, 2005 | 03:08 PM
Robert56's Avatar
Make sure the wire isn't oil coated from your recent oiling/filter change. Also, maybe try aiming your nozzle into the air stream, as it could be getting past the maf and does happen sometimes. but if you have a spare maf to try, that would be great, but try to eliminate other problems before buying one. good luck.
Robert
Old Dec 12, 2005 | 04:42 PM
white2001s10's Avatar
If you're running CATs in your exhaust and the WBO2 was put in the tailpipe or behind the CATs then that would explain it.
Otherwise, it's probably a placement issue.
Doublecheck your commanded AFR when this is happening.
Old Dec 12, 2005 | 07:05 PM
Sport Side's Avatar
I'm using the stock Y piping but, the cats have been gutted clean.
I'll have to check out the commanded A/F.
What exactly do you mean by a placement issue?
Here's a picture.
Thanks.
Old Dec 12, 2005 | 07:12 PM
Is that your MAF sandwiched between those large diameter metal tubes?
How big are they anyway?
It may just be a case of too much air space inside the tube. In that case you just move the nozzle closer to the MAF and aim for the wires.
Old Dec 12, 2005 | 07:20 PM
Sport Side's Avatar
Yes, that is the MAF. I believe it is 4'' tubing.
I appreciate the ideas... I'm going to give them all a
shot as I try and get things working correctly.
Thanks.
