Nitrous Pressure Discussion.
Ricky
Or have the bottom exit noids with a sealed mount on the base of each runner. Come up with a way to put the jets right at the exit of the noid/entrance of the runner. Definately a project but doable. That would eliminate any room for the n20 to expand to a gas as its traveling through the lines and/or rails towards the nozzle.
Ricky
Ricky
Ricky
With white2001s10's results:
https://ls1tech.com/forums/nitrous-o...t-results.html
We can see that increasing the pressure provides an even greater reduction in the temperature of the surrounding area. From the 1300 to 1700 psi tests we see a greater area affected by the reduction in temperature. On the other hand we see that even though the test was done over a period of 3 seconds we see a larger pressure drop in the bottle that would be even more accute as the test time increases.
Now, with the mass marketing of push systems and their increasing popularity I'd like to see a kit adapted to running and maintaining the bottle pressure at an extremely high pressure. With out having done the test what are everyone's thoughts and / or opinions.
Robert
Cyipher touched on it, but never got a response. I think it would be interesting to be able to use a push system to pressurize the bottle to around 1500psi while maintaining a low bottle temperature. Of course the added pressure is going to increase the temperature of the nitrous, but no where near the amount heating it would.
Robert
