Purge Line Question
Old Dec 20, 2005 | 11:05 PM
227Hawk's Avatar
[QUOTE=Homeslice (tm)]My point is that the purge is just a "looks" thing. Why spend the extra money and extra trouble wiring?
Willling to let someone else pick this up........
Hawk
Old Dec 21, 2005 | 09:23 AM
WS6HUMMER's Avatar
Originally Posted by NXRICKY
Purging into the engine during a burnout is not recommended even tho some do it,,, Not everone that is doing a burn out is at full throttle...
Thanks for interjecting Ricky, I was taught this also and was trying to explain it in my above post. Unfortunatly I dont have the reputation or background as you so most people here arent as likely to beleive me.
Some call it banging the motor.. Basicly allowing the nitrous system to burp into the engine..
I have had this term explained to me and defined as "Bliping" the Nitrous.
Old Dec 21, 2005 | 10:16 AM
Loadre's Avatar
I just use AN line, which splits into a T with two more AN lines that exit the cowl.
Old Dec 21, 2005 | 10:44 AM
WS6HUMMER's Avatar
This is a pic of my system when it was setup on my friends car, now I know why the purge linewas so short.
Old Dec 21, 2005 | 10:54 AM
fastlt1's Avatar
Originally Posted by Homeslice (tm)
A more important question is why are you purging? Unless you need to drop bottle pressure there is absolutely no need for an external purge. Just purge in to the intake during your burnout. It is by far a better at eliminating gasses in the lines than purging at a point before your main solenoid.
I don't understand. Are you just hitting the spray while burrning out? No purge kit.
