Question on mounting of solenoids
Old Dec 18, 2005 | 11:27 AM
cruzzn's Avatar
Default Question on mounting of solenoids
what would the performance lost be if I mounted my solenoids in the battery compartment of my C5?
rod
Old Dec 18, 2005 | 11:38 AM
227Hawk's Avatar
Dry/Wet/??
The performance will be the same just take longer to hit. The delay will be from solenoids to nozzles. If wet you just need to watch delay time from fuel on to
n20.
hawk
Old Dec 18, 2005 | 12:03 PM
cruzzn's Avatar
Originally Posted by 227Hawk
Dry/Wet/??
n20.
hawk
I have nx (wet kit). I will be running my fuel line next to the n2o line. Will this take care of the delay time with the fuel?
rod
Old Dec 18, 2005 | 12:30 PM
sbcgenII's Avatar
Nitrous is under more pressure so you could run lean for a split second depending on the lenght of the lines.
Old Dec 18, 2005 | 02:46 PM
JoeyGC5's Avatar
Rod's only runing a 50-75hp size also.
Old Dec 18, 2005 | 03:18 PM
cruzzn's Avatar
Joey,
I think I am going to bump it up to a 100 shot.
rod
Old Dec 18, 2005 | 03:40 PM
stangsteve's Avatar
Dont think id run two long lines from the noids to the nozzle, seems t me you would have too long a lean spike.
Old Dec 18, 2005 | 04:13 PM
camaroextra's Avatar
i wonder how long stangsteve's sig is gona be up?
Old Dec 18, 2005 | 05:26 PM
NXRICKY's Avatar
Closed ex-Sponsor Account
That is a really long run from the noids to the nozzles. 5 ft plus depending on routing.. I think that is too long of a run... You will see a pretty good lean spike..
Ricky
Old Dec 18, 2005 | 05:58 PM
NitrousDirect's Avatar
Just keep in mind.. when mounting noids, you want the best air flow to keep them cool, heat is the enemy! You want to try and keep them as close as possible, too far away could result in a lean condition, also won't hit as quickly
Old Dec 18, 2005 | 06:30 PM
cruzzn's Avatar
Thanks a lot guys. All of you basically answered the same way. Looks like I have to find a better place to mount. Thanks for answering my question.
Rod
Old Dec 18, 2005 | 10:25 PM
Robert56's Avatar
Check my web site, my normal location is on the pass front head. Easy to make a mount for that location. Works great and your much closer. You could even mount fuel noid right on the end of fuel rail, then n2o noid on head mount. Lots of choices really.
Robert
Old Dec 19, 2005 | 10:59 AM
Nitro Dave's Nitrous Outlet's Avatar
WE carry custom solenoid mounts for the ls1.They bolt to the passenger side head.This will give a nice clean install.
Dave
Old Dec 20, 2005 | 07:51 AM
cantdrv65's Avatar
Post
Dave
I have one of these, very nice piece.
Old Dec 20, 2005 | 11:00 PM
Thank You
Dave
