Can I run 100 wet shot on my stock motor with no problems?
i want to get a nx wet kit. i dont want to add any more than a 100 shot. can i run that without any upgrades from stock? what the best recommendation? i have never ran nitrous and have no clue about it so your input is much appreciated. thanks!
Yes you can spray a 100 shot on there with no problems. Check out the dual nozzle special on our Christmas specials.
YOu will need to change your spark plugs to NGK TR6s. I would suggest a window switch for saftey. and a heater,pressure gauge, purge and fuel pressure safety switch would be items to help the system work to its full potential.
Dave
Dave
I sprayed through about *70* 10lb bottles on my stock '98 motor with no problems.Shots ranging from 75-150.I used an NX wet kit that I purchased from Nitro Dave I liked their products so much I opened a shop and sell and install them now
Just make sure you get all of the safety items available for your nitrous kit and be careful with and you should have no problems.Everything listed by The Nitrous outlet(I don't know if that's Dave posting or not) should be used to get the most out of your N20 system.
As has already me mentioned, the 100hp wet shot should be no problem for your stock motor and drivetrain. I highly recommend all of the accessories that Dave mentioned as well.
Chad, that is a hell of a story for customer satifaction. Glad your so happy with the product.
