help with gauges
Old Dec 20, 2005 | 03:15 PM
project nightmare's Avatar
Default help with gauges
i made a custom plate that fits in the compartment between the seats for a fuel pressure and nitrous pressure. i bought the jimmy jams switch panel fot eh ash tray. i wanted to be able to see both gauges because the bottle will be in the back and im trying to set -up everything reall sneeky like. how do i get the fuel all the way back with out T it at the fuel rail.. braided line is very expensive.. is there any alternative to what im trhying to do.. thanks josh
Old Dec 20, 2005 | 08:02 PM
NXRICKY's Avatar
Closed ex-Sponsor Account
YOu will need to get a autometer fuel isolator.. You never want to run fuel into your compartment.. Now that thing is not cheep but neither is the carpet in the car, if you have a gas leak.
Or you can get an elctronic fuel psi gauge..and just run wires.
Ricky
Old Dec 20, 2005 | 11:21 PM
Nitro Dave's Nitrous Outlet's Avatar
If you need someone to build you a gauge panel to mount them in the console we can.
Dave
